menu bar and missing toolbar
  • Thread starter Thread starter tmeinventor
tmeinventor
Help! !
by 14:00 I have to make tables and I have seen the menu bars and tools
what worries me is the menu bar (the one with files, edit displays etc...) from which it was possible to activate and disable others, how do I get it back? . . I find nothing on the guide
thanks for every help
Help! !
Okay, what are you doing? ?
However you should just press the right button on a gray position (where you had the bars before), and there is a drop-down menu.. .
Help! !
If you're missing, but it's like you're "scancellate", that's the space where the bars were still there, but it's empty, just try to get over it with the mouse.
otherwise click with the right on any point in the upper area above the graphic window (where should be the bars); a window appears to you,
see if your bars are deflaged by clicking on customization and see if you can pull them out... .
Sorry it's 2009...
menu bar I can't find it anywhere I've narrowed that tool
no standard inventor is the one with new, open and true things I mean the one above without icons...but it is strange that you turn on the pc on Monday and find it gone...or if you tell me that it is included in standard inventor the thing worries me even more...until if active and disactive standard inventor that does not appear to me...can you make a test?
Sorry, but you tried to right-click on the gray bar (e.g. up to dx), a drop-down menu opens.
from them selections personalizes, and in the tab "ambients" always up to dx there is "reposed menu bar". .
I did, but nothing...but in fact if you try to turn off the various menus...the menu bar can not disable it.. We have two licenses... which allowed me to work. ..this seems to me a problem kiss style...maybe some update of xp winodws that bothered him. . .
arrived at sti points I don't know if you have to edit a file that brings this bar to the inventor.. .
I have no idea on the internet is not clear what to do :confused:
Since you have 2 licenses, you can, from that good export the .xml file, which you can always generate from "personality/export". . .
Then it matters in the high pc. . .
:wink:
Would you please tell me where I find this file?
always do dx button on any point where you had the bar.
from the drop-down menu choose to customize and choose the room tab, below you will find the 2 keys "export" or "import"... the file you carry out from the "good" pc, save it in any position of the "corrupt" pc.
do this, reopen as described above the drop-down menu, and go to recall it with the "import" button. .
I forgot to tell you, that the file to export is a .xml...(however you will see it alone)
Hi. .even at m and time ago a similar thing happened with the control panel...it was gone, and also going to check the voice in the "famous" drop-down menu did not reappear a good thing then a nice day... is reappeared in a corner of the monitor.... mysteries of inventor and/or computer science:biggrin: :biggrin:
