menu_def. will the cosa serve?
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning to all,
I searched in the forum for some discussion that talked about it but it doesn't seem to me to have found anything unless there were any discussions before the forum was restored some time ago.
someone can explain to me what the file needs (PHP 4 = 4.1.0)?
good work... for those who did not go on vacation
good holidays ...for those already with the c..o in water (sweet or salty it is)
once it was used to customize the drop-down menu (which was the only proe menu) by setting up your voices pointing to macros, or setting menu items as if they were already "clicked"; but since (packaged versions now) there is the toolbar no longer use this configuration; the macro can also be inserted as icons in the toolbar and changes are saved in the config.win.
here's how it turned out proe 14 years ago ... only these fantastic drop-down menus that were unrolled next to the graphic window: :wink:
thanks to the intervention,
14 years ago it served to what you indicated, you want to tell me that today although present among the configuration files is an unused file?
for me yes, even if it needed to change those very few menus left, I do not see the utility
