mesh ansys
  • Thread starter Thread starter ygna
ygna
Hello I am modeling for the first time a masonry building as elements I defined solid45; what can I suggest the steps to be taken for meschatura? (from tutorial nn I understood a lot and the program gives me error). . .
Thank you in advance.
First of all, you should take into account the choice of the single finite element. say solid45 is very easy. you should consider material characteristics, behavior under certain loads, applied loads, etc. a solid element 65 could be used for stones, concrete, and anything else. go to "element types" in help and, according to your case and the characteristics of the elements proposed, make a choice.
However you could start by making mesh with solid45 elements to have a first solution to the problem. then try with other elements more suitable in order to approximate more reality.
to make mesh I would recommend you go on help or just some tutorials on the internet. I'd definitely say too much.
if your program gives you error, check that its installation took place correctly.
