lucafer117
Hello everyone,
I find no solution to my problem. I am making a model of a car, the complicated part is the body shop. I downloaded from a site the body design in obj and various format. this has been reproduced by blueprints through 4d cinema. Now I would like to use this in inventor and make it a sheet, so with a physical thickness in order to make us various modifications. I have already tried with the suitable mesh command but you plant the pc. is there a way to transform this structure of polygons into a unique and continuous surface? I attach the image of the porter imported into inventor. If I did not explain myself well, I would like the door to be a unique solid ipt without triangles, with a thickness.
