mesh solids of hatred
  • Thread starter Thread starter Peinakatsuki
Peinakatsuki
hello to all, I briefly explain to you my problem.
I created two solids: a cylinder diameter 100 mm and height 1 mm and, rested on the top base perfectly in the center, another cylinder diameter 10 mm and height 200 mm).
Now I have to create a mesh for both, but I need the mesh of the contact solids surfaces to have the matching knots, so then to merge the two objects with "merge".
I hope I've been quite clear.
thanks to all
peinakatsuki
