Ragsta
hello to all
It's just that I've been using ansys and given the infinity of errors that you can make I address to you.
I have to simulate a metal bellows made of two lamina of 0.25mm thick subject to a compression of about 170n.. .simulation that should be really simple but...
from experimental tests the bellows should compress 3mm but simulating with ansys the result is 2.1mm.
I initially thought it was due to the mesh but also infixing the result does not change, then I tried to verify the type of element used but also in this case I got the same result.
for a further verification I checked that the thickness of the blades was correct and it was as specific (0.25mm) while on the simulation only going down to 0.22mm I have a shift as from experimental testing.
In your opinion, where I may have made a mistake, the bellows on ansys is too rigid.
thanks in advance
thanks in advance
