mfg con proe release 2001 e wildfire4
  • Thread starter Thread starter aserf
aserf
Hello.
I recently passed from proe2001 to wildfire4.
in wildfire4 I imported a mfg created with proe2001, the sync that generates wildfire4 is not the same that I genero with proe2001.
I used the same post processors and pprint table of the 2001 version.
on the config did you address the 2001 directory?
in the release2001 generates a config.pro file where you indicate the path of the gpost folder.
both in release 2001 and wildfiire4 I entered the postprocessor folder in the main directory.
maybe in the gpost folder of wf4 deletes everything and put that of 2001, doing, of course, before backup of that of the wf4
hello,inwf4 already exists a gpost folder with a ready-to-use pp package.
I took the pps I used in the release2001 and copied into the gpost folder of wf4,when it generates me the n.c the program is not
equal to that generated with the 2001 version.
I always have the same problem, I hope someone will help me.
Perhaps it will be table pprint?if someone uses wf4 could send me table pprint?
