microstation problem
  • Thread starter Thread starter tiziano69
tiziano69
Is it possible to make the measurements rounded to +/- 0.5 example 10,4 becomes 10 - 10,5 remains 10,5 - and 10,6 becomes 11?? ?
I do not speak of tolerance or alternative units, but of the possibility that it was present in autocad to establish a rounding threshold.
but this sets a tolerance in +/- compared to the measured, does not determine rounding. In summary, I would like to have unitary measures or more with 0.5 or 100,5 but not 100,4 +/- 0.5.
I don't know if I was clear.
I have never seen a rounding like this:confused:
I've read too fast.
@roar
yes you can do this in autocad, or set how many figures must be present after the comma and their rounding.
the only defect is that 10,5 becomes 11 if I remember well ............... But I might be wrong.
@tiziano
in microstation is always there where I indicated you, it was enough to change the last menu:
element > dimension styles > geometry > units and then change, at primary pleasure and secondary units, and their accuracy
to get the desired effect.
should work
I've read too fast.
@roar
the only defect is that 10,5 becomes 11 if I remember well....
you remember well,I this rounding to the upper decimal,from 5 up,to the decimal inf from 4 down,I know it,it would miss use creo,I referred to the rounding all autocaddese 10.4 becomes 10 - 10,5 remains 10,5 - and 10,6 becomes 11
