mid-range sweep for calculation length
  • Thread starter Thread starter makeng
makeng
Good morning, everyone.
I searched in the various forums the solution of a simple problem: calculate the length of a sweep also the different sectors. to better understand I should in fact calculate the length of a cylindrical spiral (molla) by measuring the line of half-work . but how do I get it? definitely (spero) at the solution is around the corner....but I don't even see that!
but to create your spiral you didn't use a curve as a path? Can't you measure that?
hi, usually for the springs I create the helical surface (and not the solid) and the intersection with the curve representing the average diameter; then use the curve as a rif for a variable section sweep (suppressed in my model)
