mirror feature
  • Thread starter Thread starter mamobono
mamobono
Good morning to all
I would have this question:
when I mirror a feature in wf3 example a hole this should be the exact copy of the original and so far nothing strange but if I change the original hole because the mirrored copy does not update?
it seemed to me that the copy was dependent on the original and therefore should follow the changes (even a simple increase in length of the hole )
have you verified that in the mirroring options there is the check on "copy as an employee" ?
I've been out of the office and I'll answer you now.
I confirm that the addiction sectage is plagued
since it doesn't always happen to me as soon as I find the problem I will try to post the file
thanks and hello
