mirror glass!! !
  • Thread starter Thread starter ottenio90
ottenio90
Hello, everyone, I wanted to ask you a problem! I have a continuous stained glass window divided by mountaineers at a distance of one meter!! I created the mirror glass material with a lot of texture for reflection...only that when I launch the rendering on all the panels there is the same image!!! Is there a way to get the image to see all over my window?? Thank you in advance! !
I doubt it strongly. ...
I think so.
I never managed to map my 3d roofs with a bitmap that gave me an ancient roof. It was the same bitmap on each tile.
for you a solution there would be;
leave your panel by putting a transparent glass and build a unique glass window just in front, keep it visible only in 3d views and on that you break your image
combine the solids or surfaces that make up the glass.
edit:
Oops, this is revit, I apologize... :tongue:
Thank you so much, everyone, I think that what he said makes 54 is the only solution!! as always make 54 good advice, a true master! !
