mirrored patre quotation: it is possible automatically.
graziano-g
hi, having two equal and opposite parts ( mirrored ) completed the table of a part is not that by chance there is the way to associate the table of the mirrored part then get it automatically? Thank you.
make a copy of the table, rename it, open it and "replace model reference".
If you've worked well, you'll have almost everything done.
If you used the command that derives the part, with the cabbage that saves some quota, it is already so much if it keeps you the layout of the views.
and don't tell me that the others fall.
If the other cads do it I don't care, I use inventor... the part has been mirrored inside a set with the appropriate command passing from the -mir file and then renamed it maintaining the connection between the applied laviations that update the slave part starting from the master part
if the other cads do it I don't care, use inventor
I didn't want to show how big my cad is, which makes me miss out on alternate days... was absolutely useless information in response to stefanobruno
once I had to make a very complex design of a perfectly mirrored part in a short time, I converted into dwg and mirrored everything compared to a vertical; in the end it worked :)
I do not understand the spirit of the answer so I do not repeat. I read the strategies and stratagems to overcome limitation, laziness, inconvenience. In my opinion they are grotesque but above all not being parametric or referring to the same piece seen in front or back vanify the functionality of the cad as soon as the mirrored part presents a difference simply due to the lack or addition of a hole. then it is also true that everyone uses the tools as he believes. It seems that this is not normally possible. Thank you.
