AndreaG85
Good evening,
I wanted to ask you something: coming from cad as creo and solidworks, I was accustomed to the fact that mirroring a component, this was mirrored completely, i.e. I then found myself in the tree a part with couplings also mirrored compared to the original. in inventor instead appears to me the symbol with the book and the bug above, the code of the part (right), points and axes and nothing more. and of course, at every change, the mirrored parts do not automatically take the changes of position made on the "original" ( mirrored naturally).
but the problem is that I can't even change the constraints because inventor doesn't let me see them for the mirrored parts.
would someone explain to me if there is a different way, and similar to what I require, to make the mirror (with clearly visible and editable constraints) and in case, how to do it?
Thank you very much
Thank you very much
