missing applic. stress analysis
  • Thread starter Thread starter Jarno
Jarno
Greetings to all.
I have inv pro 10, point in white does not leave me the solicitation analysis menu.
I have not modified anything on inventor, so the possible guilty are either xp updates (professional 32bit) or installation of adode acrobat professional or demo of m-files.
What road do you recommend? I'd hope I didn't have to uninstall and reinstall everything...
Do you have any licenses on the net?
could be that you left inventor suite instead of pro
try charging the module: Additional tools/modules search simulation: dynamic stress analysis and simulation
I thank you for your interest.
Mine is a stand-alone license, i.e. inv. It is installed on my pc, so let's say that I "inventor suite" don't have any around...
As for the modules loaded, I see what I put in the attachment, I would say the right module is aipstressadd... but it was loaded, I also carried out tests to download and re-load it, but nothing changes. I suspect a problem with adobe flash player (it seems to have updated recently) but also there I tried to uninstall it without result... Maybe I should have re-installed inventor but you understand that I don't die from wanting since it takes at least 2-3 hours of work.. .
But isn't that you're in the environment together? version 10 does stress analysis only of single parts
Well, you obviously don't know me of fame, but I see that in this forum there are few of my time.
cmq, no, gentlemen, they are not in assembly, they are in part.
in inv 2011 if you do dx next to the bar, those of the icons to understand us, on the vacuum the context menu-->display groups--> simulazione and the snack. try to see if there is the same menu also from you.
great greed.
there is no voice that you mention but doing dx on the command bar (where there is "expert" x understand us) there is analysis and now it has reactivated anceh in the browser! Thank you.
