model skull
  • Thread starter Thread starter tekno
tekno
I hope you can help me, I'm looking for a 3d model of a human skull.
You know where I can recover it?
test also with the keyword "cranium" or "skull".... the medical term is skull, not skull;) however there was a software (which I also have) for anatomy students, it is called virtual skeleton.... Maybe you can get some files out of there.... ;)
during a university course that also includes the cad, they explained to me that there are software that use digital images of tac to create organs and bones of the human body. so, if you have a tac of a head, and see if you find these programs (names should be: material mimix and simpleware), you can get the model like this.
the problem is that files of this type are never solid cad models or surfaces.
you will find only mesh type files (obj, stl, 3ds ... etc.).
so, if you want a step or an iges, you should reverse the above files.
is an expensive process in terms of time (and therefore of money).
It's not exactly right. depends on the thickness of the cuts made to the tc, otherwise the detail loses.... so it depends a lot on the reason why the tc was made... if you have a multislice could go well, otherwise it loses in detail! !
@tekno if you're still playing around with skull models, check this one out: Human skeleton HD
Full skeleton scan, but the skull detail is seriously next level. You can see all the tiny anatomical stuff, perfect for references or realistic sculpts. Might save you some time.
