Nicolas
Good morning to all,
I write about a difficulty with pro-e wildfire 5.0 in modeling parts in the environment together.
I have to model the "b" part using a profile of the "a" part (e.g. a geometry of the hole-perne type).
I proceed as follows:
- active the part "b";
- I define the sketch plan and its references;
- use command. but the attempt to use the lines of the profile belonging to "a" does not show.
we checked with a colleague the procedure on pro-e 4 and it works properly.
is the procedure correct or is something wrong? or do you need to define a set on the sw?
thanks to all and good day
