modeling of a carnival mask
  • Thread starter Thread starter windreef
windreef
I should make the solid of a carnival mask (Venetian type) x mean to then print it with the 3d printer.
to how much I read it is recommended to use mesh modelers, but willing to realize it with inventor is a fight with windmills according to you?
thanks to all
thanks to all
Let me know the cat, door subdivision surfaces oppur shape sculptor
hello thank you x the answer.
But I don't have a casket I used it where I worked before now I use inventor.
So doing it with inventor is madness I seem to understand
I model with inventor, carry in stl and use a software supplied with the printer to import stl and print it.
with inventor I see it hard to shape a carnival mask.
I would say that the print part is the minor problem, now there is a special tab within the same program to set the printer.
Moreover having a solid you can export it to stl and it is already enough for printing.
I would try to use "crea froma libera".
or if you have the possibility/demand to make a 3d relief and then import the cloud of points of an existing mask and then with loft/swip do tests.
