marcok625
hi, reading the message in yellow, about what is not a forum I return in full in the category of who asks for a solution "naturally when I don't get there alone" then I don't make myself feel until the next problem.
I tried to try to answer questions asked by other users, but I'm probably not so experienced that I can give targeted solutions.
said this I ask my question.
I would like to make a vibrating cup, but I can't find the controls to achieve what I want.
I came here:
in 3d geometry in 3d curve another and selection the spiral command 3d/helical shape
in the window that appears to me select conical type and I make my line 3d conical spiral, then I create a plan on the starting point of the line 3d and I build a rectangle that would be the ascent of the vibrating cup, and with the command in model under other use add rototranslation, until here it seems to me to proceed in the correct way, but at the moment when I make horizontal preview my retangle then as it follows
Does anyone of you know a solution or another method to get to the same result?
Marco besana
I came here:
Marco besana
