modeling shovel of a fan
  • Thread starter Thread starter vigno
vigno
hello to all, I write to you for advice on the work I'm doing for the graduation thesis. I was given a model in the form of iges files that was originally created with toptron. I should correctly import geometry into pro-engineer. The only problem is that this model is imprecise, i.e. blades have building defects. some of the surfaces that compose them are not connected. I tried to correct the object somehow by clicking "modification definition" but I can't change how I would like geometry because I don't have all the sequence of operations that I normally would have if the object was created in pro_engineer. Do you have any advice? ? ?
Thank you!
