modeling toothed belt
  • Thread starter Thread starter dema
dema
someone is able to denigrate a t10 belt by making the tooth follow the profile properly.
I attach the belt with a tooth like me passed it I just discarded the pattern because it didn't work.
my eternal gratitude to those who explain how to do it:biggrin:
Hello, dema.
we in the company create a curve of the primitive profile of the belt, we create above two distant points of the tooth quota therefore, taking them as a sketch reference, we go to build the tooth.
Once completed we collect the points and extrusion, then we send in series at a costly pace. is a small mistake in the size in the tooth but it is very negligible.
thank you, it is more or less what we do in fact adding a bond that was missing we managed, I hoped there was a simpler way. . .
then if you open the part old_hiking is the straight stretch of a belt shaped piece by piece first the straight stroke then a curved, moral trait when in the studio a pulley moved, after changing the sketch it jumped all the rest.
then we tried to remodel everything so that the various processes are all daughters of pattern, so that in the future at the change of path do not skip everything again.
we are almost at the end the biggest problem remain the holes that are to be created at the axieme level that is the file 0es15632.asm the cut in the external carry does not keep the distance from the sunbeds
thanks to who can help me
Staff online
