rob76
hi to everyone, I wanted to ask you if you can edit a .stl file with solidworks.
thanks to all
thanks to all
Sorry, I'm not so practical, I wanted to add or remove material.explain what you mean to change is to ask too much?
you can try to rebuild functions, but you will have sketches without quotas; functions will be without modeling logic; it is not said that all succeed according to the complexity of the model and its import (the imported surfaces are always a snare)
instead you can remove and add material and deform the imported body
