Greg_!
Hello, everyone!
I apologize if I bomb the discussion forum, but on August 20 the poli is duly empty and there is no one who can help me for the thesis!!!
here is the question:
finished the design phase of a geometry, with so much mesh, loads etc. how do you go edit the .ses file, for example to make changes to geometries, without changing the other settings?
simplified example:
design a square perforated plate of side 100, do mesh, define loads etc.
how do I edit directly in pcl, to change the side, bringing it for example to 120?
until geometry is simple I can do it from the command line, calling the functions "crea curve" and setting the desired values.
but if it is complex you need to edit from the session file.
Did he get to do it?
thanks in advance
Greek
simplified example:
thanks in advance
Greek
