moldovawizard - manage the load of parts of a set
  • Thread starter Thread starter simlaz
simlaz
Good morning to all
I have to create a set to manage with the standard parts, together that will be constituted by a component always identical to itself and other components that depend on the choice made.
the example could be a water dispenser block in which the block, which always remains identical, and the fittings that can be of different type depending on the choice.
a solution could be to seal the block with all possible fittings and guide its suppression through an expression. In this way, however, we carry a set with a high number of components, most of which are suppressed.
I would like to have a system based on which, when the type of fitting is made through the standard parts, the axieme loads only the chosen components and takes only these.
Is that possible?
the system would be there, but it is quite complex to explain.
I recommend you search for information about part family
Thanks for your usual interest.
Let me understand...the difficult method to explain is always about part family or is another method.
I ask you why the intention would always be to use the standard parts panel.
