moldwizard - inserimento standard parts
  • Thread starter Thread starter simlaz
simlaz
Hello everyone
I would like to know if there is a way to simultaneously insert a same standard part into a number of preset points. . .a kind of automatic insertion.
in solidworks the function is
"repetition guided by the sketch"
in practice repeats the selection (which can contain anything.. lines, curves, surfaces, bodies...) based on points of a sketch
but do you want to insert feature in the partfile or assemble other partfiles to your original?
ug does not work as sw
my intention would be to inherit the same standard part at the same time in different points ... a little like I would do for the mold columns, in fact, or for the cooling caps (we use the std parts and not the cooling command)... or for other 1000 other situations.
I use standard display of a component
Obviously to speed up the whole standard part has memorized the constraints, so with 2 clicks I entered, then without leaving the command I put the rest.
