molle a gas
  • Thread starter Thread starter gtemp
gtemp
Good morning to all,
I have seen that there are on the market gas springs that have a manual mechanical block that drives turning a wreath that blocks the stem.
Can you tell me how this block works?
I've never seen one, but if you put a photo, a link or something, we can see better. If the locking is at a certain point, it means that there is a notch on the stem. otherwise if it is possible to lock it in any position it means that the wreath goes to press a conical rubber pad that under pressure of the wreath is tightened around the stem. There could be other plausible solutions.
I saw him at the vapsint stand at a fair.
I think it's a rubber conical swab that under the pressure of the wreath is tightened around the stem, if so are these swabs on the market?
classic motorcycle suspension! You can make recordings thanks to the wreath!
Try to see a cross motorcycle and see how it is done! there is nothing conical, it is a wreath and a counter for the clamping/locking, it is used to record the piston stroke and also affects the intensity of the piston! I did a lot of recordings when I competed, for every kind of terrain you have to record the race and the intensity! on my blog there is a photo of one of the many motorcycles I had! [CUT]:finger:links should be placed if relevant; We don't link to the house. Maybe a box was easier.
mod
the most effective means of getting fame is to make the world believe to be already famous
jacomo leopardi
politely before making rash statements documented better, otherwise you risk mistakenly drawing the inexperienced people who fail to understand the conceptual errors present in your answer.
the initial question has nothing to do with this answer.
I looked at the vapsint site and found two products that could be the ones you're talking about:
the "gas top", but it seems to me to be a hydraulic block:
http://www.vapsint.com/index.php?pag=prod&id=7&m=3_2and instead the "push top", which has a mechanical block to the wreath (probably a sort of bayonet or graft) that however works only in the position of all open:
http://www.vapsint.com/index.php?pag=prod&id=8&m=3_2
but did you see a motorcycle suspension? :bekle:
jacomo leopardi
But who's saying he's famous? But I don't want to be offensive.... to do the moderator you have to be like you? :biggrin:
the operating principle of a cross motorcycle suspension is identical, there is also the voltage regulator placed under the saddle, there are motorcycles that mount it on the steering! :finger:
I ask tonyproge to be careful and not to open 3ad so, so much to open.
here you are not making a contest about who writes more and if you want to quote more answers fall on a single 3ad. There are rules and it seems to me that you are violating them (up is not allowed, but it is not the only rule not fulfilled).
I also do not accept attitudes and criticism of the mods when they behaved correctly.
attention therefore. Thank you.
Bye.
Bye.
I thank you for your remarks, but I would also ask you not to neglect statements that some moderators make on some of my quotas! I just try to answer what they say! Thank you!
1. If you (I give you the general rule of the forums, you then give me some you not of her!) reply to my intervention you do not need to quote since your answer follows mine.
2. I'm just trying to do my job. in your reply, in my opinion, you were unclear and the link (which I have deleted) was not relevant. it would have been better to put a link to the operating scheme, we are designers and we talk with the drawings!
3. I read some of your discussions and I have to say that you have a tendency to respond with sometimes unfriendly tones. Of course the other people take it.
I do not want to make further arguments, but I ask that the debates be technical and that there is no tendency to be superior to others. We're all on the same boat.
Greetings.
Greetings.
Thanks again, but my forum colleagues often go heavy! and if you allow me finally I feel that technical discussions must be at the center of attention! In short, this forum is the top for these technical arguments! only that some of the times are permalous:confused: Thanks again!:finger:
.. sincato, I wasn't there tonight and I missed this of the motorcycle/cross shock absorber; usual nettles (and also competed:biggrin:).
but let it be lost for a few days until the water is quiet.
only a notice to those interested and do not know the subject:
shock absorbers do not work absolutely as well as summarily and undeterminedly "explained", do not go to tell around.
Marco:smile:
Mannaja I missed this and the other... congratulations guys, you were very good :36_1_18:
are more than two years that I am enrolled in cad3d and I had the luck and pleasure to meet many people. among these many extremely competent ones who have certainly enriched my modest baggage without ever assuming attitudes from "superman owner of absolute truth".
with many of them we exchanged the so-called "friendship" which is among the atre things, a statement of mutual esteem.
have been some of these that have allowed me to enter the nous of moderators (and I thank them so far) and as they have accepted me, they can at all times revoke this appointment.
them, not you.
So, you don't offend me at all.
