monitor resolution greater than full hd
  • Thread starter Thread starter SE-Bologna
SE-Bologna
hello to everyone, I have to change monitors and the option would be between these two
lg 27ul500 27" 3840x2160
lenovo c27q-35 27" 2560 x 1440
would then be coupled to one of the two full hd from 23 I use now
experience on change resolution? problems with solid edge?
for experience it is better to have monitors with the same resolution (general speech not only for solid edge); even better if the same model.
Okay, thank you, it's hard to get two.
I wondered if the writings were legible or if it became too small
solid edge supports high resolution monitors already from different versions. the problem is that setting large texts in one monitor and small in another can cause some problem in software that do not predict this situation.
