more detailed plant
  • Thread starter Thread starter kubbah
kubbah
I would like to ask for advice on how to disembark a more detailed plant only part of the project (e.g. 1 apartment)
sena pero these details (floors, or additional furniture) are seen in the display of the global plant
I'll explain.
I need a plant at 1:200
with less details of all apartments
and a 1:50 plant with more paviemnte furniture etc
the problem is that if I impose the view on a single apartment, and I begin to add things.. they will also be displayed in plant 1:200
And then I'm supposed to go back to 1:200 and turn off objects, right? ?
Is there a more "ingenious" way that surely revit proposes? ?
in the view to 200, instead of turning off the single object, turn off the family (e.g. family furnishings) and all the furnishings "spark"
and for the pavients?
Can I draw only in a single view?
if I disengage a pavement on 1:500 also appears on 1:200 ...
Maybe then I miss something.. Isn't there a more "revian" manner to do that?
thanks in advance
for floors, what do you mean: the floor itself (family of floors) or the surface motif of the floor?
in the first case, you must always operate with "specs" for single object (or family)
In the case of the surface motif, for example, the escapes of a floor, which in the 1:500 scale would become an all-black floor, you can use:
- use a pattern pattern, which remains constant in size, regardless of scale;
- use a "retino" to overlap the floor, in the view that requires a different reason.
there is also the command: plant views, which allows to assign to a determined area, a different level of view than the level of the main view.
p.s. it is useful to indicate the reason for which the solution of the question is required (e.g. in the view of the pt you should not see the external sidewalk that is at the same level of the inner floor ...), as, according to the specified result, there may be several solutions.
