motion and subaxis work? ? ?
  • Thread starter Thread starter Gio_RS
Gio_RS
by doing motion studies I noticed that if I realize axioms using previously made subaxioms and then I do a motion analysis,solidworks is not able to realize the correct simulation, since it sees subaxioms as parts; for example a ball bearing (subaxieme) poked on a tree, if I give the rotary motor to the shaft rotates all the bearing subaxes and does not see.
Is that what you're saying? or is it possible even with subassienas do a correct study of movement? ?
you have to make the "happy" subset that otherwise by default is "rigid".
right click the axieme and place the check mark in the appropriate box.
p.s. "rigid" "flexible", "structural members"... oh, but who put to translate the interface, the sister of moana? :biggrin:
Yes it is true translation is not of the best even in the tutorial there are things that do not fit..... I did not know this thing, effectively it seemed impossible. . ..because if the axieme is formed by many pieces and does not resort to subaxis... between the parts and the couplings. .:eek:eek:...there is to shoot....
I can't find these rumors you say...flexible,rigid....I only see fixed or mobile
in the hurry I forgot to tell you that (sw 2007) in the drop-down menu at the wheel that opens with right click you have to enter "component property" and find the option to fix it rigidly or flexiblely.
Of course, if you were searching for a keyword flight (flexibly help) in the help, the explanation about how to manage subassiemi you found it immediately... :rolleyes:
eye to not exchange forum for helpdesk; a little healthy debate on basic issues such as these can only benefit. :wink:
