ferdinandonardiello
good evening, kindly I would like to know where to find information for the use of motion of unigraphics nx7.5. Thank you.
thanks for the advicegood evening, kindly I would like to know where to find information for the use of motion of unigraphics nx7.5. Thank you.
Do you need sporadic information or do you need a course?good evening, kindly I would like to know where to find information for the use of motion of unigraphics nx7.5. Thank you.
ip design hi, I have already read in other posts talking about nx manuals.Usually roads are 2
the first is to carry out a course at siemens
the second with the online guide
of course the first is definitely the best road, but economically more expensive
there is also a third opotesi and it would be to buy from siemens the manuals that are provided at the courses .
I don't know.
in what is + powerful? or what limits does the cat's dmu have?I intend to extend it to the motion of nx7.5 having known that it is even more powerful.
"I know." .in what is + powerful? or what limits does the cat's dmu have?
Good evening, everyone. I just joined the forum so I also present it here, after doing it on the appropriate section: My name is morning and I'm mechanical.Do you need sporadic information or do you need a course?
if it is the second is right ip design.....if it is good the first try to ask
to a certain level maybe we can explain to you
Morning,Good evening, everyone. I just joined the forum so I also present it here, after doing it on the appropriate section: My name is morning and I'm mechanical.
from about 20 days I started using nx 7.5; the fact is that there is not much material on the web so I don't have to bother you and ask for some advice to more experienced users.
In particular, I also have a problem with motion simulator, in the sense that I do not understand the function of the individual types of joint, universal type or spherical. .
I tried among other things to make a model similar to the one proposed in this link:http://www.youtube.com/watch?v=sdfuwznzcdoBut I can't make it work. Does anyone have time to lose to give me two straights? :smile:
thanks in advance
Morning
Sorry to read me again I realize that for the rush I was a little superficial.Morning,
How I understand! I had to get into these troubles at first, too. We come to the point.
if you have too many constraints the system does not move....but if you have too much freedom, this drawback happens. I at first had put all the spherical joints (so with great freedom) and at some point the system had given me an error message so I converted the spherical joints into cylindrical joints and everything has settled. Of course, as you see in the video, you have to put on a "revolute" that makes you as a motor to your system... I hope I've been at least a little help
Hello mauro
First of all thank you very much for the availability.Morning,
Hello mauro
Okay I answer myself, a nice "slider" is great for us:I take this opportunity to ask you an opinion: which joints would you use, in particular between cylinder and piston in this example?
http://www.youtube.com/watch?v=0nzanpzwpti
is his death!! :finger:Okay I answer myself, a nice "slider" is great for us:
