motion wrapping scheme
  • Thread starter Thread starter Split
Split
happy to all, I have been reading your forum with interest for some years now, full of suggestions and that has answered my doubts several times thanks to the competence of all of you.
we now come to my request....I would have to perform with solidworks a movie like the diagram attached. in short the parcels on a tape are stacked and a nylon band is wrapped around the raspberries.
is it possible to do this with motion or should you use other software?
thanks in advance
thanks in advance
then the first part is simple to set, but if you have no motion bases it is not easy to explain, for wrapping with the nylon band I see it hard to do, maybe with some trick you could do something but I still see it hard.
Yes the initial part I already started to throw it down. I have allpicato a fade of emergence of the boxes, a linear motor and a coupling of the parallelepipeds on a guided path to advance them. for the nylon band I had thought, about the trick, to do as much. show it before the winding and then dissolve to finished parcel, simplifying so.
already because to show the winding phase, it seems really complicated.
If you are looking for the post where I gave the explanations for handling a conveyor belt you will find straights and even the 3d model, the video and the notes of how to do it.
here is the link qui
I have a precision 4600, 8 gb ram, intel core i7 , use solidworks 2010 I can not make movies greater than 2 gb...solidworks creates an empty fle avi or impossible to open
Can someone tell me something?
in rendering or in normal graphics?
I had had problems in 2010 but only in making movies rendered, problem that I solved in this way:
compression
microsoft video compression program 1 compression quality 100
configure time ratio 100.(This way it stopped creating corrupted avi files)
I don't know if solidworks 2010 has limits of size (I filmed by more than 1 giga I never managed to make it), however you can always split the video into several parts and join them later.
thanks in advance
to do what you want there is no need for motion, the basic license is enough.
It's clear that if you didn't take a course on animation, it'll be hard if you don't get what you want.
compression
compression quality 100 ok
configures time ratio 100...where?
to join multiple parts in one movie which program tips
when you set the time report there is in part a key configures if you press on it opens a window with the time report,
I had used to join them window movie maker, but it's not the best, in the sense that you have to find the right resulution to import it into movie maker without losing quality, maybe on the net there is something better but I can't tell you, if you know some chart he can tell you for sure:biggrin:.
I don't know graph
between a forum and the other seems good virtualdub-free
