psx2
Hello everyone,
I trust in your help because I arrived at the last beach!
I have a diameter board of 1.5 meters with a weight of 350 kg, the table rests on small pieces so the performance is great.
above this table I can place 6 pieces equidistant and the center of these pieces is from the center of the table 710 cm.
the table must turn at a speed of 5 mins with a acc and dec of 2 seconds, for the transmission I would have thought to a gear motor and with pinion and crown.
now considering for es a 800 minute gear motor with a reduction ratio i equal to 7 I would output 114,28 rpm
to get my 5 rpm I should have a ratio between the pinion crown equal to 22.8.
the problem is that I have no idea the engine power to use!!
I have tried to search for san google but there are formulas that to me (not being of the sector) are impossible to understand.
Can you clarify my ideas?
ps: forget, the load could be unbalanced in the sense that I could only charge 2 pieces instead of all 6.
