move a block to another layer - bug?
  • Thread starter Thread starter Fabio M.
Fabio M.
Good evening,
I am trying to move on layerb a block created on layera but it happens, at least for me, a strange thing; the object remains of the layer color and if I turn off this layer, the object in question also disappears. contrary, if I select it and look at the properties, the object results of the layerb
:confused:
sometimes even me
It seems that you don't always understand but come back as you say; I did another test now and actually the object is moved to another layer even if it remains of the same color (but that I think depends on the fact that it is a block).
happens because the object properties are anchored to the layer where the block is defined, and not to the layer where the instance positions.
because the layer change has the effects you want to redefine the block in a new layer, I don't think there is a way to edit the layer of a already created block.
read the help online: levels, groups, and blocks/blocks, where it says:
"block instances and modelsthe properties of the geometry (curves, surfaces, etc.) contained in the block instances are controlled by both the properties of the levels and the properties object of the geometry itself. Lock instances inserted in the model are inserted into the current level and cannot be moved to any other level. There is no relationship between the level in which the block instance is located and the geometry contained in the block. For example, the block geometry does not change to combine with the color level in which the block instance is inserted.
when the block contains objects on a certain level, if we deactivate the level, we will disable only the objects found on that level. However, if the level in which the block instance is inserted is not active, all objects will disappear. "
