move components to axis from the browser
MARCOC
good morning to all, once on inventor it was possible from the browser to move the components or assemblies to other assemblies, directly from the browser by moving the component with the mouse directly on the icon of the assieme, now that uses 2018 does not make me do it if before I do not expound the axiom in which I want to insert the component.
Yes, he always did.
you must first "open" the target axieme by clicking next to the file name ">" , then push the other file inside it, also determining the location on the target browser
And yet I remember that once it was possible, I believe before 2016
cmq thank you very much
I repeat here, because the problem and the same, even the work plans created does not make me reorder them in the browser, leaves them in the position where they or created them, I remember that I always moved them to the beginning as a first function
Do you know if a check has been added somewhere that prevents such a reorder? ? ?
Thank you very much
I would say that you can't move a plan over the processing that generated edges and reference surfaces... ie: if a plan is created with an offset from the face of a solid you cannot go reorder the plan above the extrusion that generated the solid. if the plan is an offset of one of origin instead can go where it wants. I'd say it's always been like this...
It's true, but it's just what doesn't make me do anymore, the plans generated by original plans don't let me move them, so I have a problem with the installation.
thanks catafract
you can have created a plan with a offset from the base planes, but if you projected a edge, everything depends on the edge.
