moves components
  • Thread starter Thread starter solokite
solokite
Good morning
I was using the command restructuring; I was moving under components (c) into a set (a)
the subcomposers are contained in a joint b
is there not a faster way to eliminate the subset b leaving the sub components c bound in the axieme a?
in trying to move some parts I get this message
attempt to add element father after the son. Unbroken renovation.
hi, I suggest you open the subset b, select in the tree the components c , then copy ctrl c , then pass into the axieme to from which you have removed or suppressed the subset b , ctrl v e reposition the copied components.
I do that.
I do that.
I already know this road but there is a small problem
I have already made a table of assembly that has as references these components
Is there an alternative?
some components (c) make me move/restruct others no and I don't understand why
if I make copy and paste I have to give back all quotas in the 2d
I do that.
you want a ctrl x
Does anyone have an idea?
Regulation
7) capital - it is forbidden to write using all capitals. on the internet is equivalent to shouting, therefore it can bother[...]9) up - the practice of responding to messages to get them back to the top of the list (see up!) is to be considered prohibited. a forum is not a chat, you need patience to get answers.
