Tequila
is available to download the MP12 for the st1
then complain if one goes from competition... .particular documentation does not exist, there is only the txt already mentioned. to know that such macros are not "covered" by the service service, they are to be constrained as they are, sona for free use, have the vb source files so that the user can use them for exercise/comprehension purposes of the vb development on solid edge.
to me began to give error only after installing the mp12, first all well both with the original batch.exe and with a modified version.It happened even before, I reported it to assistance on 20/05/09 with mp06
I remember a similar problem in the past, I seem to remember that it was a setting, I try to investigate.Oh, my God. .
from a couple of mps entered a limitation in the draft:
it is not possible to select the line style type unless it is in "2d model" or in "drawing in the view".
a fertile and boring discussion could arise about the fact that by forcing the user to draw only in the two circles mentioned you get to a more ordered design, but here are the uncomfortable:
- it is a drama to add two rows on sheet 1;
- it is a drama to draw the section lines in the cutting plane, which is an ambinete full of bug where with qlk distraction erases you views the odds, and not to confuse the thousand lines of the views I used to draw them with an obvious style;
- they force us to draw in the views while with their functions to automatically add the axes, the axes on sheet1 are drawn out from the views and to a 'reviewed update' problematic are found flying objects not indentified.
how can you return to drawing freely?
