mpc slider
  • Thread starter Thread starter pasmat
pasmat
I'm building a model where there's a shell to solid transition. It seems to me that I have understood from the documentation that this constraint does not guarantee that the solid section remains flat, and so it is practice to use together with the shell to solid also the mpc slider. This bond is not supported by the cae and must be inserted into the script, i.e. inp. After a whole day, I couldn't make it turn. I'll take back the part of the.inp I wrote. I have written the bond within the assembly and following the shell to solid bond, as the documentation says and as it seems to me to have understood, but it does not work. Someone can tell me what the command sequence to type to get him to take the mpc?thank you. Matteo
** constraint: sts1
*shell to solid coupling, constraint name=sts1, influence distance=2.5
** constraint: sts2
*shell to solid coupling, constraint name=sts2, influence distance=2.5
sts_shell, sts_solid2
**constraint: slider_1
*mpc
slider, 8,13,19
**constraint: slider_2
*mpc
slider, 5,14,18
**constraint: slider_3
*mpc
slider, 7,16,20
**constraint: slider_4
*mpc
slider, 6,15,17
*end assembly
