msc patran 2012.1 does not show mpc - bug solved
Prozak85
Guys,
I take advantage of it to report you a problem in which I have come across recently after updating to version 2012.1 of patran.
as you will have noticed who already has it, this version has a somewhat annoying bug: the command shows/hides mpc does not work, forcing to work without being able to display the mpc.
to solve quickly you just download the .ses file that I bring back in attachment and call it back (file-->session-->play) after opening the .db of your interest.
for the most experienced instead, you can solve it at the root by adding the command lines contained in the .ses file inside the plc file.
in all cases, the 2012.2 version should include this update.
I hope I've helped you,
Say hi.
