multi axis creation
  • Thread starter Thread starter luragne
luragne
Greetings to everyone.
I wanted to know if there is a possibility or if a method comes to mind, to insert the axis of a circumference in a multiple way.
Specifically in a plate I have many round holes made of "cut out" and I have to insert the axis because in the table I have to quote its center.
it would be nice to select all circumferences and with a single command and insert the axis.
Are you doing it individually or am I wrong?
thanks to those who answer me.
Why are you doing all this?
If the cut has been made with circumferences, the axles show you without this operation.
in drawing environment just use the show/hide command and activate the axes.
I know that. the cut is of surfaces.
amount my solid for example a punch in a set, which has the seat of its housing made of revolution as surfaces, then followed the cut using the cut of surfaces, so as to have the seat of the already made punch.
Why not use the operation function with components?
if you do so the axes are created with the function itself.
Thank you, I'm trying!
Effectivemnete with the remover option I care about the axis.
Maybe you mean an imported solid?
..in that case I think you should do one by one, otherwise you should do as maxopus says.
