multi-body bolean operations
marcoevolution
Hello everyone: modeling a fuselage in top down mode and going to create the windows of the control room, I used the "insert body" function in which defining pockets for extrusion and applying the intersection command between the created body and the part body I managed to pursue my goal: problem--> catia now does not show me anything...as if the created and interconnected solids were ghosts. . .without possibility to change view and without possibility to change in display type
What happened?
How can I fix this?
I have already tried to change the reference for display (circled in red at the top in the figure) and to delete the command "material application" but nothingALTRO PROBLEMA.webp
try to see if below displays is disabled geometry....... I am not in front of catia: (I hope to remember well
I solved... I changed the transparency of the body 2 but also modified the part body...sorry if I lost time
