multi camera background
  • Thread starter Thread starter Shape
Shape
Is there a way to assign a different background image for each room inserted in the project?
I explain better, if I have to make photosinserimenti I often find myself having 2.3 or 4 photos from different perspectives, and I have to make renderings to insert then in these photos, so now I do alt+b select the background file to align the view and click on apply to active view, I use the prospective match to align the room and then I make the render.
then insert new rooms, al+b etc... But I realized that if I have to remake the rendering of room 1 I find myself as a backdrop always the last file loaded even if I select apply to active view.
Where am I wrong?
Thank you in advance.
p.s. 3ds max design 2014.
Yes, you can do it using the "scene state" and "recording changes", you should however indicate that it was used to make...you know that you first create several files 1 for each backdrop. . .or create a cylinder and break the foundations previously united and adjusted with ps....ciao
