multi core x4
  • Thread starter Thread starter chip_20
chip_20
Hi, I have a phenom x4 965 and I wanted to know if with sw 2010 he works with all 4 cores or only with 1 core. :redface:
thank you and good we
chips
from what I read I could do without spending money for a quad that will never work in quad-core. patience.
thanks samp:frown:
thanks samp:frown:
is a bit like the discussion for "back lifts":biggrin:; it is known that no cad fully exploits multicore processors.
However, I would not consider the investment useless, because they are processors from the most modern and fast architecture and at the same frequency the processing capacity is higher than the dual.. even on a single core work better and intensively exploiting programs at the end you notice the benefit.
I also passed last year from dual to quad, and while overclokkando the dual at higher frequencies I find that the quad overall goes better.. I'm finally satisfied.
Marco:smile:
chips
the parametric cad as sw, if, iv, pro-e, catià, nx, etc. in history feature form can not exploit the multicore.
the sketch that generates extrusion, on which you create a ray or a sform are linked together in a sequential way.
until the sketch is generated, the extrusion does not generate the faces and until the faces are generated, the sform or the radius are not created.
However, there are functions that can exploit the multicore.
at part level repeats for example.
to the level of asses, the loading of the parts.
in drawings the creation of views or regeneration.
the fem.
rendering... especially photoview360.
These are some examples you will certainly understand.
So don't worry, you made an oculated purchase.
thanks solid, I chose the processor according to some specifics suggested by the same dassault, i.e., sse etc., then, I have 8 giga ram 1600 patriot and nvidia framework 600. Perhaps the only flaw, on the contrary it is, is the hd clavier 500 giga western digital, a bit slow but on the other hand I had to stay in the badge available. cmq, the machine is fast. a rendering to the maximum definition with photoview about 20 sec. I think it's good.
Hi chips
