camale82
hello to all, I wanted to ask you these 2 similar but not equal questions.
1: table 2d of a first sheet set with distinct and bubbles, then n sheets with impaginate the parts of the axieme, and so far all easy, the encoding scheme is 12345 for the assembly and 12345-01,03,04... for the parts of the axieme obviously code and file name go hand in hand.
when I start the table starting from the axieme, then in the field cartiglio code appears to me 12345, when I create the second/third/fourth sheet with the individual parts the field code remains 12345 and not 12345-01,02,03 etc.
Is it possible to release 12345-0x in the following sheets? What do you have to write in the $prs field...?
2: Same thing I would like to do with multi-body parcels, i.e. first sheet with full part and distinct table with relative bubble, successive sheets with individual bodies, the part has code 12345 while the bodies will be appointed 12345-01 etc in the cutting distint will have a code property that will bring back the body name, then 12345-body0x, at this point I would like to do the same thing as mentioned above but referring to the multi-body part.
thanks in advance.
thanks in advance.
