multibody and separate components
  • Thread starter Thread starter FrankWhite
FrankWhite
I have the problem: I am using the multibody with inventor 2010, I am making a boxed beam with reinforcing sets inside. First of all, in the view in section, always keeping the half-way of the original planes, I create the lower piattabanda, superiore and the two external souls and I create 3 blocks and 3 solids (3 because the external souls are equal).
At this point, always from the plane of origin, I create the whole sect that is inside the beam, I create the sketch, I make the block and the bond, then to replenish the other pieces, always in the same sketch, I always take that block and I repeat it, then constraint in turn all these blocks with step 2000 example.
Now I have this repeated internal set 10 times.
I create the components, with the appropriate command, and I make the table; But when I go to call back the list of parts (structured), I realize that it sees me for every solid 1 piece,Instead of me for the inner septum and for external souls I need to display 10 pieces and 2 pieces.
My question is: is it not that to see how many components I have, I must serialize the parts in the classic axieme, what I create next to understand?
is there no way to display the right number of components in the list of parts, working only in the multibody?
In practice I would like the list of parts to recognize me how often the piece is repeated in the multibody.
I hope I explained. Thank you very much.
Unfortunately no can be done (called as frederich franchenstein)!
it has been said to be able to read the distinct composition of a multibody but for now we have to arrange with what we have. In your case, in the multibody, I would create one sett and then serialize it together.
I thank you, I have proceeded exactly as you said, but I have lost a lot of time! I don't use multibody anymore!
