multibody solid connection replacement
  • Thread starter Thread starter Bobo75
Bobo75
I write here asking if this is feasible. I have been using caia for more than a year, still without course and come from about 15 years of solid edge. premitting that I find this software really sluggish, little intuitive and sometimes with behaviors from "uccs" (office complication simple things ) not having done a course I'm still blaming myself, but I don't know if it will last much longer this consideration before going to blame the software and not the person.. .
finished or come to the request.
I created a part using the multibody speech (which I was not used to coming from solid edge ). But I was wrong to link the solids. I'll explain better, I've made a pasted copy with connection to the various solids for the boolean operations I needed. but I did the operation from the files copied on the work folder and not from smart team (pdm ) and in this case there should be no problem, the second series however I did the special paste copy from another part where there were the same works assuming erroneously that if on that file the connection was from the friezes copying them on another file the program would still fish the connection from the friezes and instead not the fishing from the final file. ...
Is there a way to replace the links by going to copy from the original files without having to make it all over again? (which I would find quite absurd).
Does there also exist a way to review in the part the solids of the body copied to create constraints in case there is forgotten to do so in the first instance?
I hope to receive answers that help me avoid doing all over again.. .
thanks in advance
to explain a little everything I don't think it is possible and cmq not constructive......... so at first glance I believe that you do not have (not having done courses) familiarity with catia v5 , I did not understand much of what you try to do and why you do it so .................. post some pictures.
then catia is catia... solid edge is solid edge, you can't approach a cad trying to get what you would do with solid edge, ............ Are you just drawing??? Nobody showed you anything in 1 year......
but where you bought the license did not offer you a course, I see you also use the pdm smart team ...... then you will be tied to a company that markets catia
I believe that a basic course is better to have it, to begin to understand how he reasons ca............ .
cmq places the photos and your doubts that we see to help you......... .
post some pictures, I didn't understand if you're talking about catia the cam part or the cad part.
What are you talking about?
cmq post of the pictures we see to help you.
but the file of the “frese” folder has the same name as the file you say “fish from the final file”?
thank you all for the answers. I think I've solved it without having to do it again, even if a little bit snout. in practice re amounts my processing from the correct file, I go to use the substitution on the command removes giving it references on the new import and works. only thing I have to fix the constraints of processing.
in this regard how do you view the solid of a command remove in the part to be able to bind it if you have forgotten to do so previously?
Bobo75,
If you do not send at least one image with the tree, you do not understand if you work in product, copying body in parts or in part design where you have a part in multi body i.e. with more body in the same part, and what constraints are you talking about, if the body are originally or repositioned!
then you didn't answer my question... I need to understand if you save different files with equal names, even if in different locations. . .
I'm glad you get to the solutions alone going for attempts, but for me it's like you go to the mountains without map and without advice from someone, if you're lucky you get to the destination doing a lot of extra effort but you can also end up in a cliff.
the diruption in this case is the fact that catia wants unique files and that it loads in memory according to the starting and search positions in the folders according to the settings and that if you do not master the “saving management” or the interruption of the links with “send to”, it is easy to end in the cliff.
You know what I'm talking about?
