multicorpo
MARCOC
Hello everyone
a question..when modeling in multibody, is there a way to get him to associate the same bodies?
I turn off better, from the multibody I create the axieme derived with solids inside, but he creates a solid for each body
and therefore the bodies that in the part are serialized (e.g. a series of 4 bodies) he creates me 4 different solids, and in distinct I find 4 voices instead of one with quantity 4
Does anyone know if possible or how you handle this?
... maybe putting the same number on solids?
in theory should make it a distinct sum
I usually proceed like this:
I put in a set my multibody.
I create and insert in the axieme the various components derived from the solids of the multicopro.
when against a solid in series, I generate the part of the first solid in the series.
then inside the serialized axieme this last part by hooking it to the working series in the mutlibody part with "select series processing"serie.pngthen usually the multibody part lets it off inside the axieme and in "hidden" so as not to see it separately.
hello and thanks for the answers,the program will go to better understand if it can serve me,for the other 2 answers I currently make a mix of the two things,but I was looking hoped that someone had a better and less slender way but okkkk.. .
another thing exists in plugg that allows me to change the name to the files automatically me three concert the multibody together?choose a progressive? currently on milcorpi of 100 details from the inventor standard you have to input the name of each part manually (because I can not save them with the name proposed by him "solidoxxx)
hi matteo... I downloaded the app, but I don't charge it on inventor (2020)... you tried it? ?
I did not install it in 2020; but I saw that it is accredited until 2021
In the old post, the problem had been dealt with, and thanks to the help of the group, several results had been obtained. Perhaps you may be useful:
