multifoil drafting export
  • Thread starter Thread starter madmax78
madmax78
Hello, everyone. I am trying to export from drafting, in dwg format on multiple sheets. the result is that I can export only one sheet at a time, as I would like it to create a single table with all the sheets. Is it possible?
thanks to anyone who can help me:smile:
hi, one table with multiple sheets is not possible
you can create a single dwg that contains multiple tables,
basically in autocad you would find more sheets as a nx.
the different output you get by setting a different version of autocad, e.g. with acad 14 only one table, while acad 2005 all tables .
I hope I have clarified
I'm sorry, I've been very ill.
I practically create a master model, and I have to split the quotation into several sheets. Then, for customer needs, I must export the various sheets in dwg format. I have tried in various ways using always 2d exchange, but the result is that I can export a dwg at a time. can I export a single file containing the various sheets?
I was thinking that if you only need a table containing multiple sheets you just have to create a huge sheet and insert the various files, putting the views in the desired files.
