Technopro
Good morning to all,
Do you think there is a way to model a part to "multiple races" in creo?
I would have the need to model small assemblies (e.g. clamps and supports composed of 5 or 6 electro-welded parts and subsequently machined to the tool machine) and then export them in step.
I would like to get these components as part files, but make sure that they behave like axiemi (for example, the coupled and welded sheet pieces should remain separated both in the display and in the next export in step ).
I tried with the "non-attached" function but maybe it only works in sheet metal environment. . .
Thank you, hello, enrico.
