multiple mass property assignment
  • Thread starter Thread starter paoanti
paoanti
I wanted to know if you know how to make a multiple assignment, i.e. on a set with multiple parts, mass properties, i.e. density. without having to open each part go to settings> pro.massa>density... sufw4
you can do, as long as you manage mass properties through materials and that the individual parts have already loaded the different materials, so by doing you can go together, select all the details you want, dx key, change parameters and you can change the ptc_material_name of every detail remaining in total
from the model tree, activating the column with the material parameter .... always that, as dani-3d rightly said, the materials are loaded in the parts.
there would be another system but, previews the use and organization in advanced assembly.
from the model tree you can activate the "density" parameter and bypass the material....
I believe that this is the right question. Is it possible to exclude a part of the calculation of mass property in a whole without using simplified representations?
