negative of the piece
diciassei
Good morning to all,
I designed a heat exchanger as part. for the purpose of modeling thermal flows the simulation software also requires me to have the "solid" 3d of the water that is inside.
being complex geometry I wondered if there was a possibility to create a negative on the side, or generate a solid by filling areas, or still to coarsely sketch the volume of water and subtract the exchanger.
Unfortunately I did not find answers related to inventor.
the question was not exactly the same, but here you find the solution:
