nervature sampling
  • Thread starter Thread starter valebiro
you the piece is obtained by melting in shell with its shape..change something this during the modeling phase?
anyway thanks for the answers. I'm in the first place and I don't know much.
Of course it changes because they do not have to be made through ribs because they are not!!!! but by emptying the material and faster and more immediate, they may seem like ribs but are not if the detail is analyzed:biggrin:
there is also the "developed view" that allows to obtain the a-a section of the design object of the task.
while the previous design is a straight section, then the rib remains behind.
I agree with rs4: that is not a rib but an integral part of the model.
Mar
But then why aren't they dissected on the 2d?
you are right that according to the rules both ribs and bolts that trees generally etc are not to be dissected, I do as I described before with more body and then delete the section in rib,
but I repeat you have to run it with more separate body otherwise he sees full
at the time when I did the course of mechanical designer I learned not to dissect the ribs or as the voglamo call as in the design placed by the colleague.
for what I remember, nothing changes if it's a rib or an extrusion.
both in the section view must be presented in full.
